Timing belt change woes...sound file and hood issues
Well I replaced the timing belt. It all went pretty smooth as far as the install. Anyways I started the car and it sounds like it has some belt whine going on. I don't think it is the ribbed belt even though it was also replaced. I can not find where it is coming from exactly. I at first thought the TB might be rubbing up against the plastic cover that houses the belt. When I removed the cover durring the install there was a spot you could tell that had been rubbed a little. If you get your nose really close it smells like rubber not burning plastic....So I thought maybe the belt it too tight? The bently manual stated that after everything is done you should tourque the tensioner in the tension direction and then the tensioner should release properly. So I am thinking is not working properly and now it is sitting too tight? If that is the case will the tensoner fix its self in a few miles? Will I have to be diving back into my engine bay? Here is the sound/video clip so let me know what you think......
TB Movie/Sound (~929K)
Also I need to now add coolant. But unfortantly the cable to release the hood is not connected the the latch or something. Since the TB I have opened and closed my hood about three times. Well now the lever in the cabin will not release the hood. I imagine the cable has come off the latch. How should I go about opening the hood? I tried removing the lever that holds is thinking I might be able to get some extra pull with it off and then it will open but abandoned that thinking it wont solve anything the two bolts holding it on are imposible to remove. I removed the grill but unfortantly the front lever used to open the hood after it is released seems to be blocking everything. Maybe if I know exactly what needs to move in what direction I could triger something. Any thoughts or ideas on this? Thx in advanced
p.s. the sound clip makes it sound like it is pulsating or on off more than it really is
RE: Timing belt change woes...sound file and hood issues
When my hoood doesn't open... it's because the bugs i've hit have welded it shut to the body of the car,,,, pull on the grill to raise the hood. it takes a bit of effort but it'll suddenly release (mind you..not toooo much effort..but more than you think).
240km/h provides crazee glue bug sealant.
I got under the car. The cable is not attached. I am going to get a dowle and see if I can engage the release from under the car. Any other ideas now knowing the cable is not attached at all?
well I got the hood open...Used a woden dowel and went diagnoal from the pasanger side from underneath. Was able to push the latch. So now all I need is to fix the sound.
Any chance that sound is made from the water pump runing with an air bubble in it or something? Is it almost garanteed that I need a new tensoner damper? It is a little quiter today. If it fixes its self should I still replace the damper incase it is failing?
I didnt have time to listen the sound clip but take alittle tension out of your a/c belt, mine whines a little too because its too tight.
ORIGINAL: TomRitt
Went back in and replaced the tensioner dampner. Fixed the problem, guess the TB was a bit too tight. To bad it was 120bux extra but at least everything to do with the TB has been changed now. Thx for all your help though
