thoughts on exh dv
thoughts on exh dv
seems like not a half bad little mod what do you guys think? after all youre the experts
http://www.atpturbo.com/root/releases/release091004.htm
RE: thoughts on exh dv
its supposed to open once a significant amount of boost is being made. its says that you can even hook up a boost controler to program when the valve will open, if at all. i dont know i think it could sound pretty mean and see some hp gains.
then again it might just sound like an exh leak
i can't really see there being a dramatic increase in power. #1 when open, the exhaust gases have to make a 90 to get out. #2 when closed they now have to flow past the T (where there is now a large void) = TURBULENCE = less flow = less power. I'm no expert on fluid mechanics, but i have take a course or two.
a better design would have been a Y with the valve right at the junction.
just my $0.02
just my $0.02
I have one, I didnt by the t, I welded up a y. Its nice but very very loud on the highway and it is never completly sealed. You can hear an exhaust leak at idle if u listen. There was a noticable gain with my turbo
