Thinking a slight relay issue....
Hey all,
Ok...so here's my dilemma. I installed my VDO boost guage...all was good, works great and all that. BUT...my problem is that now the panel that is under the drivers side of the dash seems to be "shorting" out my signal lights, wipers, heat, and rear defrost all at the same time. I can un-bolt the panel and pull it down, and all will work fine, and then while putting it back up it will kill everything. If I do manage to get it bolted back in with everything still working, less than a day later all is lost again. Just wondering if anyone has run into this problem b4, or has any idea what it might be? Wired in my boost guage to the 27X post under the dash if that helps any. Need to find a fix fast as winter with no signals/wipers/heat/de-frost is goin to be horrible!
Thanks
Thanks
B6S4FTMFW
11-05-2010 12:25 PM
