Sponsored by:
Sponsored by:
think I found my problem
Old 01-12-2007, 02:15 PM
JohnnyBravoA4's Avatar
Default think I found my problem
I have cleaned this up a few times and it looks like my cly3 injector is leaking (where i was getting most of the misfires) also cly2 and 4 had a bit of that crap as well 1 is perfectly cleen.. cly2 is the where i got a few misfires put not during accleration that was cly3..
would a leaking injector cause low MAF readings.. I would asume yes..
Old 01-12-2007, 02:41 PM
Default RE: think I found my problem
you definitely found the problem there by the looks of it and yes it does cause the misfire ( you can by the new O ring seals for the injectors ) it will be drawing are in there
Old 01-12-2007, 02:45 PM
well i have delphi injectors that are no longer made how the heck do i get new ones..lol
it will be drawing are in there--- im not sure what that means
Old 01-12-2007, 02:46 PM
brrman's Avatar
Leaking injector isbad in anay case. Definitely get that repaired, man.
I would think the MAF would definitely be off because of this.
Not sure what your actual symptoms are (haven't been around the forum much these days so haven't seen your earlier posts).
Are you experiencing loss of boost, erratic boost? MAF lcel?
Maybe your MAF is just bad.Or just a hose leak or bad dv.
my guess is Avant meant "air in there"
Old 01-12-2007, 02:55 PM
im getting a misfre, low maf readings during logs, erratic boost... i just put a new DV in and fixed a few leaks, dont think there are any more leaks.. if you roll on the throttle no misfire, WOT misfire and erratic boost, (roll on the throttle hold 20) it feel a little sluggish to me..
Old 01-12-2007, 02:59 PM
http://images.google.co.uk/imgres?im...l%3Den%26lr%3D
its only a rubber O ring seal real easy to replace
Old 01-12-2007, 03:05 PM
I have read on a few forums there has been a problem with these Delphi injecorts seating properly and causing all kinds of problems.. I may switch to the bosch ones im going to call APR in a bit.. i need to read up and find out some stuff b4 i take them out and make everything worse..
Old 01-12-2007, 05:51 PM
onepoint8tee's Avatar
if there are spacers where your injectors sit, take em out/off. When i was trying to help arif with his setup in the begining, his injectors came with spacers for the fuel railand the setup called for them to be used. He was leaking some fuel (i think) and misfiring with them.
Old 01-12-2007, 05:55 PM
leaky seals will cause a misfire perhaps the Delphis don't sit right and leak air, never tried them so don't know
i have to call apr and get the low down..
Quick Reply: think I found my problem
