think the DV is bad or I need a different spring
dont know if you remember my last post about that noise, but i finally got the boost gauge in and drove her hard the last few days, it almost sounds like a belt skweek or slip but it must be the DV, when it makes the noise the boost fluttersskips between 18 and 21, like the needle on the gauge bounces while you hear the noise.. so im going to have to order that kit.. any thoughts?
RE: think the DV is bad or I need a different spring
no, not really, my DV is not holding the boost its a little different, in your case you want to eliminate a high boost spike which is casued by alot of things, one being the chip, or the n75 vlave if its not stock and fluctuations in the air temp, on colder days like we see this time of year you will see a bit of a boost increase, I have a BT its more eficient then the small ko3 or ko4 and the DV i have i guess is just not cutting it.. or atleast i think..
ORIGINAL: JohnnyBravoA4
sorry its been a little crazy over here, yea the box was there, but there was only one spring in it..
