Things Audi owners may not know...
#32
RE: Things Audi owners may not know...
I can't even get a bloody 1C
in fact... I've been out there for about 20 minutes! Press the recirc button, and nothing happens, then press the up arrow on the fan control, and nothing! Then I read somewhere up there ^^^ about the 'up' button for the windscreen! Pressed that and it worked! Was getting all confused and using the fan speed up button, which resulted in much profanity, and genreal foul temper!
Workes anyhoohow, so cheers for that chaps!
#33
WHoa. THis is rad! Haha... i had NO IDEA that we could do this. Too bad theres not a Boost readout, or a EGT read-out. The RPM's are pretty sweet, and my RPM's aren't really lagged in my car. (at least not as bad as what everyone else has said...)
Thanks for the heads up on this (whoever discovered this)
#34
no problem man, by the way, are you on 18's and how much are u dropped?
and by the way, that 1c still is still unattainable for me... ARHGHGHGHG [:@]
#36
hmmmm for me (99 Audi A4) I did this:
Hold Recirc button press temp up, this changes from C to F and Vice Versa.
Now,
Hold recirc button, button MANUAL FLOW CONTROL UP , NOT FAN SPEED. The manual flow control is the up arrow on the right side. The button to chose which PATH you want the air to come.
1c appears.
Use temp up/down to scroll through the items.
Press recirc again to open specified code.
Press temp up/down again to change code.
Press recirc again to open code...
Remember press the.. manual FLOW control up button... and NOT the manual FAN SPEED control up button!!!
This should help some!
Now,
1c appears.
#37
yeah i tried that.
it seems like it should work. cuz when i hold recirc and then hit the up arrow my climate control doesn't come on like when i press any other CC button. but it still doesn't show 1c. then as soon as i let off the recirc button the CC comes on
