Sponsored by:
Sponsored by:
Thing that holds up the clutch pedal
Old 11-01-2006, 04:48 PM
acetrebo's Avatar
Default RE: Thing that holds up the clutch pedal
Move your seat back until your fully extended leg pushes the clutch just past the engagement point.
This works if you have long, ape like arms.
  #22
Old 11-01-2006, 04:56 PM
the peddle mod will probably cause more problems than its worth the system is automatically adjusted on clutch ware so the mod would prevent that and you would have gear binding on changing then you could stuff the gearbox (just thinking ) out loud it sounds cool for a quick shift on the track though
  #23
Old 11-01-2006, 04:57 PM
aRIf's Avatar
ORIGINAL: onepoint8tee
Where are you relocating the DV to?? Trunk?[&:]
ahahah no I will moved it just next to me so i can hear it louder
I will move it maybe 3-4inches far where it is right now.
  #24
aRIf's Avatar
ORIGINAL: acetrebo
you mean like this
  #25
Old 11-01-2006, 05:10 PM
onepoint8tee's Avatar
How is your industrial stregth garden hose setup holding up?
  #26
Old 11-01-2006, 05:17 PM
acetrebo's Avatar
LOL, a picture, worth a thousand words!
ORIGINAL: aRIf
ORIGINAL: acetrebo
you mean like this
  #27
Old 11-01-2006, 05:38 PM
aRIf's Avatar
I took it out long time ago It works great but I have leak or something that I need to check it friday (Friday my off day so will spend all day in garage ) my cel is on and it is slow.
  #28
Old 11-01-2006, 05:42 PM
ORIGINAL: aRIf
uh oh... Better check that IC boost sensor hole.
Audi_Skydiver
03-11-2018 01:18 PM
coast2coastdrvr
04-13-2010 12:47 PM
hayman
05-13-2009 11:38 PM
ericcota2003
03-09-2009 10:39 AM
sound227
04-16-2008 03:23 PM
Quick Reply: Thing that holds up the clutch pedal
