test pipe or downpipe?
Old 04-16-2007 | 03:43 PM
Lipscomb29's Avatar
Default test pipe or downpipe?
whats the diff. between the downpipe and the test pipe ?
and if you had to choose which one is better?
Old 04-16-2007 | 04:01 PM
akielb's Avatar
Default RE: test pipe or downpipe?
a test pipe connects to the turbo and then to the downpipe then to the exhaust. a testpipe also replaces your cat.
Old 04-16-2007 | 05:29 PM
chaos92287's Avatar
yup right after the turbo is the cat. it can be replaced with a testpipe. then after the testpipe is the downpipe. changing the downpipe prolly wont give you much gains, if any. getting a testpipe will give really nice gains, but its ilegal so if you have emissions in your state, your screwed
Old 04-16-2007 | 11:42 PM
Amze's Avatar
Psh.. theres always ways to get around the law. Thats what makes this country so great
Old 04-16-2007 | 11:56 PM
04a4's Avatar
just swap back before you go to emissions, then your fine
Old 04-17-2007 | 12:04 AM
Lipscomb29's Avatar
i went with the down pipe... but i dont think they do emissions test in south carolina. ill prolly get a test pipe later
Old 04-17-2007 | 12:05 AM
chaos92287's Avatar
^^unless you have airtools swapping out a test pipe ain't that easy. its a huge PITA to get at the cat->dp bolts on and off. the easiest way would be to just find a shady shop and pay them off to pass you. and you have a possibility of passing if they dont test your car under load w/ a testpipe
Old 04-17-2007 | 12:09 AM
chaos92287's Avatar
ORIGINAL: Lipscomb29
dont you have milltek exhaust? milltek comes with a new downpipe so why get another?
Old 04-17-2007 | 12:13 AM
onepoint8tee's Avatar
ORIGINAL: chaos92287
No dp with the b5 front trak milltek system.
Old 04-17-2007 | 12:34 AM
chaos92287's Avatar
http://www.millteksport.com/exhaust....fm?variantid=4
2.
CAT-BACK - Non-resonated
Consists of:
Tailpipe Style
Downpipe (connects directly to cat)
Centre Section replacement pipe
Rear Silencer
Twin 76.2mmJet
Pipe Diameter: 2.50" (63.50mm)
Quick Reply: test pipe or downpipe?
