temp gauge not wokring
RE: temp gauge not wokring
could also be the ECT ( Engine Coolant Temp.) Sensor being bad... costs at msost 15$ and takes 5 minutes to replace.
Do check the wiring on it though, most ECT's that go bad have erratic readings before they completely die.
Do you have A CEL?
Do you have A CEL?
CEL is check engine light right? if so, no i dont. i have checked the fuses and they are all good. but i do have another question about my fuses. i noticed that these fuse ports, dont have fuses in them:
11 - Cruise control(auto trans)
16 - ABS, ASR
41 - ABS again
the others missing are vacant in the book. should i put fuses in the ones that are missing?
also, you guys have to realize, that im a noob with this stuff. so when you tell me to check wiring. i have no F'IN idea what wire to check. pardon my language. you guys are the closest teachers and help that i have without paying a million dollars. so i do appreciate all your help.
16 - ABS, ASR
41 - ABS again
