tail light question on my B5
So..I was changing my brake light blub today..and I noticed something kinda weird. When I removed my bulb-housing thingy ( I think that's the technical term! )..I notice 3 bulbs: turn, reverse, and brake. Seems normal right? If so..what's with the empty spot on the top??? There's a spot for a 4th bulb on the very top..what the heck is it for? If you know or have an idea..please let me know..cause its bugging the HELL out of me!!
RE: tail light question on my B5
ORIGINAL: SILVER_B5S4
Oh...now it makes sense..so if I put a bulb in there I'll have dual rear fogs?? Cause that would be kina cool! Huh!?
i put another bulb in the empty slot so when people think there cool and want to ride my a$$ i hit the botton and they think i hit the brakes and get off my a$$ i works pretty well so much so i have installed a switch in my wifes camry that turns on the brake light with out hitting the brake riding other drivers a$$ is a common thing around denver expictaly suv drivers but they learn quick
theres a DIY on here on how to do it, but its easier if you just splice into the wireing and put a wire from the brake lightwire to the fog light wire and your done. i only needed to do this on one rear light for both of them to work, unlike the DIY which tells you to do both rear lights.
youwill need to cut the whole in the passenger side rear light housing to put the missing fog light in.
once you do this mod, NEVER press the rear fog light button on your dash, you WILL blow a fuse and you wont be able to get out of park if yours in an automatic.
the rear fog light button should be out/off.
carry a couple extra fuses just incase. the fuse should be labled as "rear lights" and i think its a 7amp.
ORIGINAL: kraylon
crazybk187
08-05-2013 04:29 PM
