Sponsored by:
Sponsored by:
System too lean
Old 06-20-2007, 09:53 PM
viktor008's Avatar
Default RE: System too lean
Ok,I got some mass air flow sensor cleaner and will try it tomorrow. How can I check the vaccum lines? (don't know the car very well what should I look for)?
Old 06-20-2007, 10:04 PM
Jeff's Avatar
Zombie Defense Force
you have to pressurize the charge system. there is a diy link some where on here just search for it
Old 06-20-2007, 10:08 PM
theguy1084's Avatar
Remove the plastic engine shield by turning the plastic fastener that hold it on and just do a visual check. The lines tend to break at their connections. Make sure nothing is loose. A tiny nick in a line will set that code. By the sound if it form you clearing the code and it comes right back if there is a broken line somewhere it should be easy to find. I am not saying its not a MAF or something else I just think you should do the easy and less expensive options first.
Old 06-20-2007, 10:10 PM
theguy1084's Avatar
ORIGINAL: Jeff
Its a 2.8l not a turbo......
Old 06-20-2007, 10:13 PM
Jeff's Avatar
dang guess i should read the entire thread my bad
Old 06-20-2007, 10:49 PM
viktor008's Avatar
The weird thing is that when I cleared the code it didn't show up for quite a while (two weeks at least). So it does not come right back up. I will check the vacuum lines and then clean the MAF.
Old 06-21-2007, 03:03 PM
nickellis14's Avatar
check your fuel filter too. might not be getting enough gas to the injectors. that would make it run lean. but either way, this is a problem you want to fix NOW. running lean is not good.
  #18
Old 06-21-2007, 03:09 PM
Munzter's Avatar
When it was my one of my vacuum tubes, before I knew it was that I cleared the codes and it took a little while for the cel to come back on. I found what tube it was by hearing the leak and looking for where the sound was coming from.
  #19
Old 07-03-2007, 08:31 PM
viktor008's Avatar
Replaced a couple of rotten hoses and cleared the CEL. No problems so far.
  #20
Old 07-03-2007, 09:58 PM
theguy1084's Avatar
thanks for the update...keep us posted
Quick Reply: System too lean
