system question
system question
i know this isnt the rite place to talk about audio system but i dunno what to do. i have a volfenhag amp pushes 2000 wtts but today it blew a fuse for the first time when i bridged it. what can i do so it doesnt blow fuses. is there diffrent watts of fuses and will they fit the current one? what can i do so it doesnt blow fuses no more
RE: system question
their is different watts of fuses, but the only problem with doing that would be that you might in the long run overheat your amp and jus end up completely frying it if the fuse is rated to high. so i'd be cautious with that.
and when you bridged it... did you disconnect the battery?? when you bridged it if the battery was connected it could have blown the fuse that way.
