Switched power source?
Old 10-06-2004 | 08:02 PM
gregp1962's Avatar
Default Switched power source?
I'm looking for a good place to get switched power (On when the key is on) on my 1997 A4. Any ideas?
Old 10-06-2004 | 08:36 PM
Jestnomen's Avatar
6th Gear
Default RE: Switched power source?
If you open up the fuse panel there should be a fuse holder on the top left side that is empty. I went to autozone and bought a fuse tap. It looks like a fuse, only it has a power lead on it to hook up your device. You can also remove the knee bolster behind the steering wheel and find that terminal post, and wire it up to there.
Old 10-07-2004 | 05:03 AM
brrman's Avatar
The best way to get switched power is to remove the knee bolster below the steering wheel and look for a yellow 75x post.
That is switched power with the ignition. I use it for multiple things.
Just make sure you put an inline fuse to whatever you are installing.
... yes I have pics of just about everything
Old 10-07-2004 | 04:14 PM
gregp1962's Avatar
You guys are awesome. thanks! Does the 75x mean 75 amps?
Town573
B7 Models
02-03-2014 05:01 PM
jr_spyder
07-26-2013 12:42 AM
ed suarez
10-07-2010 11:04 AM
KfabR8
08-21-2008 10:11 PM
jpat5
02-13-2006 08:53 PM
