Stupid o2 sensor
Old 05-23-2006 | 04:09 PM
techbod's Avatar
Default RE: Stupid o2 sensor
its only one sensor that's out bank2 sensor 2, if you look at the engine from the front bank 1 is to the left which is where number 1 spark plug is so the sensor your having problems with is the right side nearest the cat
Old 05-23-2006 | 04:15 PM
nmorrow's Avatar
That was a confusiny reply. So what you are saying is that i only need to replace one sensor? I hate to say it, but i had the stealership check it out. They specifically said the TWO o2 sensors after the cats.
Old 05-23-2006 | 04:20 PM
techbod's Avatar
actually they are just before the cats last time I checked but your code spefically says which sensor is bad, of course the dealer will say its both sensors because that means more cash to them
Old 05-23-2006 | 04:28 PM
nmorrow's Avatar
Those stupid jerk-wads.
Old 05-23-2006 | 04:32 PM
techbod's Avatar
had you said there were more codes then I could understand but only the one?? cant make mistakes like that
Old 05-23-2006 | 08:31 PM
wood_e's Avatar
If one sensor is bad, the other probably isn't far behind. Replace them both.
Old 05-23-2006 | 10:34 PM
sdaudi's Avatar
Does the CEL code always come up if any O2 sensor is busted?
last time i took the car to a dealership to have them check for a recall, they told me to replace the o2 sensors. but i haven't seen any CEL light come on yet. i did notice that the gas milleage was a bit lower than usual when i last filled up. but maybe that's just the gas or something. i'll see what milleage i get this time.
  #18
Old 05-23-2006 | 11:02 PM
flyboy's Avatar
**** the ones behind the cats, They are there to tell if the cats are doing there job. both of mine are fecked any car runs fine ofcourse I do have a constant CEL.
  #19
Old 05-24-2006 | 12:36 AM
david9999's Avatar
Correct. The pre-cat sensors are the ones that determine fuel mixture. The post cat sensors are there to compare to the pre-cat readings to tell you whether you catalytic converter is working properly.
ObnoxiousDrunk
02-03-2009 01:07 AM
Quick Reply: Stupid o2 sensor
