Sponsored by:
Sponsored by:
straight through
Old 11-24-2006, 08:58 PM
Default RE: straight through
totally useless it would create a vortex in the pipe because of the length which would create over back pressure and blow the engine, what size pipe do you intend to use
Old 11-24-2006, 09:01 PM
AudiCross's Avatar
Wait, which yould do that. creating a cheep cutout or gutting/removing the resonator
Old 11-24-2006, 09:10 PM
the resonator is an area for the gas to expand or open out rather than backflusing causing back pressure, if you use a strait 3" pipe with no silencers at all you would need 2 to 3 swaged pipes in the flow to compress the grass, a swaged pipe is a reducer and I recommend 2 " then 2".5 then depending on the rear box 3"
Old 11-24-2006, 09:11 PM
it will be noisy as hell
Old 11-25-2006, 04:29 PM
turbo kraut's Avatar
Tech Guru
i am planning on using no larger pipe than 2.75 pipe, cause i will probably not go bt
the only turbo upgrade i will do is to a ko4 maybe and that would be if i blow the ko3, but i could probably find someone online that is doing a bt and get their ko3 cheap
so to sum it up, i don't want noisy as hell don't want to blow anything and want to do a cheaper custom exhaust, so then the question is which muffler would sound good and not have a ricer tip on it, and still be a straight through?
Old 11-25-2006, 04:35 PM
AudiCross's Avatar
well, if you are going muffler, i believe you can go to the audi website and they se basic parts for our cars. i found it before, but im looking again. i believe they have a muffler for our cars also.
Old 11-25-2006, 04:36 PM
AudiCross's Avatar
Or a borla muffler ;-) of course.
  #18
Old 11-25-2006, 04:39 PM
Tech Guru
the one on the audi website is a "highflow" straight through?
cause if price is better than borla that would be good, the borla one i could get a axle back setup
  #19
Old 11-25-2006, 04:43 PM
AudiCross's Avatar
im not sure. it was this summer when i was looking at it. from what i remember the is showed a muffler and the tips.
A4Audi420
04-09-2011 06:37 AM
sundar_amn
10-02-2010 12:35 PM
111Audiwinner
02-04-2008 02:41 PM
AWDaholic
09-09-2005 08:52 PM
bizzle
09-02-2004 11:08 AM
Quick Reply: straight through
