storage compartment for small objects won't close
Has anyone had an issue with the storage compartment for small objects on the dash not closing? If so, can it be repaired at home ( In the immortal words of Jeff Spicoli "I Have Tools") or is it a dealer repair?
Thanks
AJ
Thanks
AJ
RE: storage compartment for small objects won't close
I would remove it and check for broken parts, then repair or replace it (you can put a second cup holder in it's place if you want to spill two drinks while rocking some tight corners!)
http://forums.audiworld.com/a6/msgs/7600.phtml
Good luck!
Good luck!
RoccoConQueso
06-10-2024 01:29 PM
