Stock Bose Radio Issue
Ok, so last night I went out to my car and noticed before I even got in that my radio was fully lit. I turned the car on and off and nothing changed, so I pulled the fuse cause I didn't know how much it would run down my battery before I found out the issue. After doing a search I found that at least one or more people have had this issue and just pull the battery or fuse to fix the problem then enter the radio code. I'm just wondering what can I do to further prevent an issue like this again, and also how much does the stealership charge for a new radio code?
Actually, I also found in the search that the code should be on every on e of my dealer invoices. But which number is it and were would it be located?
Thanks alot!!!
Thanks alot!!!
