Stock Bose + Amp and Subs... Capacitor Needed?
RE: Stock Bose + Amp and Subs... Capacitor Needed?
the reason a cap generally is no good is because with the amount of power that it stores it is depleted after one large hit. so if there is another hit before it can recharge then it is pointless (and no its not like an instantanious recharge it takes a few seconds). the second battery you install in your trunk and hook your amp directly to it. then you wire the battery to your other one. with this when there is a large hit it will draw from the battery in the rear of th car and not your alternator. this 2nd battery is much harder to deplete than a cap because it can hold more amps.
and as for a bomb in the tunk........ thats what fusses are for!
if your only going to be running 400 true watts (RMS) then a cap nor a second battery will be needed.
carmichael1620
04-06-2013 09:51 AM
Silver98A4
06-18-2006 01:55 PM
