RE: Stealership.
No, that means either your brake fluid is low, or the float inside the brake resivior is bad.
RE: Stealership.
Okay because the light is still flasing after i took it in. I also checked the brake fluid to see how much they put in and they barely filled it past the min didnt even top it off, i dont know if there is some audi policy against toping it off but that also kinda pissed me off.
RE: Stealership.
they also said nothing about the resivior being bad
RE: Stealership.
Its against policy to top off fluid un-less its listed in a major service or major repair. So topping off the fluid yourself would be the first step in fixing the flashing light, it has to be completely topped off.
RE: Stealership.
Okay that makes sense then. Also does being a second owner on the car take away any warranty coverages?
RE: Stealership.
No, year and mileage affects warranty, you could be the 10th owner it wouldn't matter.
RE: Stealership.
Okay thanks for all the help you cleared up alot of unanswered questions.
