Sponsored by:
Sponsored by:
Stalled
Old 07-23-2007, 01:24 PM
Kimble's Avatar
Default Stalled
Need your help on this one.
I was sitting in the drive through and my 2002 B6 A4 3.0L started to rev up and down whenI was in neutral and my foot was on the brake. It was reving just below 1,000 RPM then it dipped down and went up and down from 400-1,000 RPM on it's own then it stalled. I ran the check engine function and everything checked fine. It started up right away after but it seemed weird.
Wondering if anyone has had this issue before?
Old 07-23-2007, 01:50 PM
Chris BLK Audi's Avatar
Default RE: Stalled
I had a similar issue on my B5 with no check engine codes at first. It was my Mass Airflow Sensor. These are sensitive to K&N filters that have too much oil on them. Did the car do it again or was it a one time occurrence?
Old 07-23-2007, 04:35 PM
Kimble's Avatar
Default RE: Stalled
It was a one time occurence. The reving issue happened the night before as well. i figure it could be my air filter needs cleaning (stock paper filter not a K&N) or the idle needs to be reset.I bought the car in May of this year and that has been the only time I've had an issue.
Old 07-23-2007, 04:48 PM
02A418T's Avatar
Default RE: Stalled
Similar issue happened to me.. Ended up being my RPM sensor, so if the cleaning/replacing the MAF doesnt help check out the RPM sensor.
Old 07-23-2007, 05:38 PM
pimptrooper3000's Avatar
Default RE: Stalled
how do u clean the MAF and when u oil the k&n how do u know when there is too much oil?
Old 07-23-2007, 06:02 PM
CRAZYHAWK's Avatar
Default RE: Stalled
You might want to do a throttle body alignment.
Old 07-24-2007, 10:34 AM
Kimble's Avatar
Default RE: Stalled
Crazyhawk,
What exactly is a throttle body alignment?
Old 07-24-2007, 06:09 PM
CRAZYHAWK's Avatar
Default RE: Stalled
Make sure you have the radio code.
Disconnect the battery for ten minutes.
Reconnect the battery and turn the key part-way, do not crank.
You'll hear the drive by wire motors moving the throttle.
Wait two minutes before starting.
Old 07-25-2007, 09:45 AM
Kimble's Avatar
Default RE: Stalled
You'll have to excuse my ignorance, this is my first Audi and I'm as green as they get, bought in May. Where doI get the radio codes, what are they used for?
Old 07-25-2007, 10:32 AM
Darknight101's Avatar
Default RE: Stalled
Radio codes are used to reset the radio "security" if the power happens to drop below or cut out completely. Without it the radio just wont work. In order to get them look in the papers that came with the car there should be one for the stero with the owners manual. If by chance there isnt head to the local Audi service center and have them look it up. Its easier if its there to deal with them.
Quick Reply: Stalled
