sport suspension questions
I have an 01 a4 quattro with a stock sport suspension and it's too soft, high and comfortable for me. I've decided to buy and install another sport suspension.
Several questions have raised when I was looking for the proper suspension for my vehicle.
What is a difference in lowering between stock sport and non-sport audi suspension?
The numbers for the suspension lowering for example eibach springs is written comparing to stock non-sport suspension. Am I right?
Is there any difference for suspension for audi's before 00 and after?
To make things clearer for you I want to buy a weitec suspension (http://www.weitec.de). I doubt somebody from you have heard something about this company, because it sells only in europe.
RE: sport suspension questions
Ok well I ride H&R sports with bilstiens shocks. I like this setup for you can go to ECS tuning and get 2 coil over kits for the bilstien shock and you have a very adj coilover for half the price. the OEM lower springs are just OE H&R sports which lower the car but only an inch and not an inch and half like the sports. But the spring rate for each are the same. you can go with the dealers OEM lowering setup but I don't think the shocks or the springs have a lifetime warr like both bilsteins and konis. (two of the best shocks to have and you must change the shocks with the springs or you will blow out your old ones) and you can go with Neuspeed, H&R.
What lowering should springs have to lower the stock sport suspension? For example what springs from h&r will be better solution not to lower my car totalluy to the ground? As I understood for myself is that stock audi with sport h&r springs will have nearly the same clearence as the stock audi with stock sport suspension? Yes or no?
ORIGINAL: Cr
I love my H&R race springs and Bilstein grooved shocks. I believe they are a little bit lower than the sport package, but its only noticable when I go over speed bumps, which suck anyway. Other than that I never ground out and the ride is awesome.
H&R and Bilstein are top notch. And you should be able to get these over there because they are German imports into US anyway...
Pson
coilovers are certainly alluring decision but every time you change your ride-height you need to re-aligne your car. And I don't think I will be do it more than 2 times.
Could somebody tell the difference between before 06.00 and after 06.00 A4 suspension.
ORIGINAL: Cr
Pson
Pson
ORIGINAL: Cr
Is there any difference becides the possibility of ride height adjustment between coilovers and shocks & springs kits?
