speedometer broken
speedometer broken
My sister has a 1998 Audi A4 Quattro, and recently the speedometer doesn't work. My dad and I have been trying to troubleshoot this for awhile but we haven't had much success. I will try to describe what is happening as simply as possible:
When you turn the key, the needle for the speedometer will begin to quiver, this also happens when you open the door. Then when you turn it on fully it begins to increase by a few miles per hour, but it is does this pretty bumpy (it jumps almost from one number to another) eventually it gets to 160 (the highest mph on the speedometer) and goes below it and stays there until you turn the car off where it goes back down and quivers. Any help would be great!!!
Thanks,
Jacob
Thanks,
Jacob
RE: speedometer broken
ORIGINAL: cyberlogicx
Is the odometer still counting mileage correctly? If it isn't, the cluster could be bad or have faulty wiring. If it is, you should check all the connections to the speedometer.
derZeck
02-22-2012 02:53 PM
EvanF
B7 Models
06-23-2010 04:41 AM
paintballcs
12-23-2009 08:26 AM
