Sponsored by:
Sponsored by:
speedometer broken
Old 11-09-2006, 08:08 PM
Crowley's Avatar
Default speedometer broken
today i was driving my car and i accelerated a little fast, and then i looked down at the speedometer and it was at zero. Then I kind of stopped fast and it would bounce a little. So I'm thinking its just a jiggly wire. What do you guys think? Is this a quick fix, maybe something I could do or do I need to take it to the shop?
thanks
Old 11-09-2006, 11:19 PM
TDRILL's Avatar
Default RE: speedometer broken
I wouldn't bet on it being a jiggly wire, but you never know.
I have never replaced one, but my guess is that its a possible DIY but probably a rather large PITA. On my dad's old car (not an Audi), it required removing the whole guage cluster and I wouldn't be surprised if it was the same on our cars.
Old 11-10-2006, 02:36 PM
Amze's Avatar
Last time I saw a broken speedometer was in a 1992 Cougar... GG
I can't even remember the entire name of the car, god I fail
Old 11-10-2006, 03:01 PM
Audi is a little different its electronic so not so easy to fix, get it scanned for fault codes it could be something else like the VSS
Old 11-10-2006, 03:08 PM
SurferForever's Avatar
Could just be a broken or loose speed sensor. Where are the speed sensors on the audi? Trans, Wheels?
Old 11-10-2006, 03:12 PM
on the transmission
Old 11-10-2006, 07:55 PM
Could just be a blown fuse, This happened on my previous car, tripped the fuse and i lose my radio and speedo... i'm so glad i got rid of my ford.
Old 11-10-2006, 08:11 PM
euro68 could be but does the rpm gauge still work if not it points to the ABS
Old 11-11-2006, 12:42 AM
Crowley's Avatar
yea the speedometer still works, and its not a fuse, because it has been working on and off. if it was the fuse then it wouldnt work at all I believe. So ifs its just a loose sensor anyone know where I could find it?
also if this matters, the odometer does not work when the speedometer doesnt work. Or at least I think it doesn't, I know the trip odometer doesn't work so i assume the regular odometer.
thanks
Old 11-30-2006, 04:59 PM
dxl2749's Avatar
my speedo starting cutting on and off also...the tach still works but i am throwing code number 16885. I recently had my tranny out maybe 2 weeks ago and wodering if it could be something as simple as the vss not being bolted down tight enough. Does anyone know if a loose vss would throw a code or if the code means that the sensor is about to go? Also is there a bolt torque spec on the sensor? thanks guys you always are lifesavers
Quick Reply: speedometer broken
