sparkplugs.. BKR7E's VS PKR7E's
just like the post says I need to know the difference.. I replaced my PKR7E's with BKR7'S and know have an odd misfire issue dont know if its the cause but it might be.. wanted to know what the differecne was..
RE: sparkplugs.. BKR7E's VS PKR7E's
Dont know about PKR7E, all i know is a lot ofthe BT guys here and on other sites like to use BKR7E. Do you get a CEL and fault code when it miss's? Make sure your gap is correct. If the gap is too big,high boost can actually blow out the spark and cause a miss. I was getting miss's at mid to full throtle before and diagnosed it as a coil pack issue, but it turned out to be a couple cracked plugs. Check that too. Ive never heard of anyone using PKR7E though.. Maybe try BKR7E and see what happens.
I have the BKR7E's in there now caped to .028, I noticed all the stems on the coil packs were a bit warn out and beat up.. can you just change out those for the 2000 a4.. i know you could with the AEB cars.. ill check all the plugs but they are a week old.. the car ran great for a few days.. I have no codes
ORIGINAL: JohnnyBravoA4
