Source for radiator petcock/drain plug?
Old 02-04-2006 | 12:49 AM
TroyS's Avatar
Default Source for radiator petcock/drain plug?
Neither the Volks or Audi dealer that i went to today listed a radiator drain plug for my 98 A4 1.8t. Neither thought it had one, until i mentioned i used it several times today. The "Haynes" manual says theres one too. Anyway, anyone know where to buy one?
What about a magnetic 26mm engine oil drain plug?
Old 02-04-2006 | 06:56 PM
dankhound's Avatar
Default RE: Source for radiator petcock/drain plug?
I think thats only available with the radiator. Personally i never use it as its easier and faster to use either the lower rad hose or the coolant temp sensor. Why do you need one?
Old 02-05-2006 | 07:06 AM
TroyS's Avatar
Thanks for the reply, mine was stripped out sorta. Someone put green anti-freeze in their, so i changed it out last week. Good to know about the temp sender though, i'll look for that if have to go back in there. (GOD I HOPE NOT!)
Old 04-13-2007 | 04:43 PM
jeffabalone's Avatar
anyone can get this plug? or any OE parts # on that plug? I went to dealership two days ago, the guy told me need to buy complete radiator... Can not just buy that plug.
Old 04-13-2007 | 05:34 PM
Audi_Skydiver's Avatar
go to a junkyard or something and look around there,
Josh
Old 04-13-2007 | 07:17 PM
ironman's Avatar
You can use the green stuff in the Audis do a search tons of members use it and have 0 ramifactations. I think ill use it when i do a flush
Old 04-13-2007 | 11:42 PM
david9999's Avatar
Sure you can use green stuff in the radiator. In 3 years when everything has corroded, then you can buy replacement parts.
Old 04-14-2007 | 08:48 AM
qUaTtRoA4's Avatar
^hahaha, keep it pink!
JMeadows
08-08-2008 01:57 PM
meanse
10-29-2007 06:04 AM
to3o
10-09-2007 09:38 PM
lfab500
02-13-2007 01:25 PM
ltcoljdf
01-05-2007 10:03 AM
