So what pulley is making this noise? (2001 2.8 quattro)
It's sort of a warbling noise at idle. Like a turkey gobbling. Pitch rises with engine speed, sounds like a faint supercharger whine at higher rpm's, but not nearly as cool.
Seems like it started happening after I had my timing belt / water pump / belt tensioner replaced last fall. Which of those would be the most likely culprit for a turkey sound?
RE: So what pulley is making this noise? (2001 2.8 quattro)
Clutch fan maybe. First off to make sure its actually on the serpintine belt take the belt off then run the engine to see if the noise is still there.
owlfanforlife67
01-17-2014 03:05 PM
derrickbush
04-12-2012 11:55 PM
