Sponsored by:
Sponsored by:
smell?
Old 09-07-2006, 01:17 AM
johnstef's Avatar
Default smell?
when i usualy drive my car a little harder then cruising mode. i smell something almost like rubber burning. not as strong though. somehing from the engine. is this normal?. by the way its a 1999 quattro manual.
Old 09-07-2006, 01:18 AM
Jeff's Avatar
Zombie Defense Force
Default RE: smell?
clutch
Old 09-07-2006, 01:23 AM
johnstef's Avatar
Default RE: smell?
good, bad, normal.
Old 09-07-2006, 01:24 AM
BadLuckAudi's Avatar
Default RE: smell?
means your clutch is on its way out
Old 09-07-2006, 01:30 AM
johnstef's Avatar
Default RE: smell?
how much for a new clutch? how do i know when its totaly out? and also do all audis clutch engage as high as mine?
Old 09-07-2006, 01:31 AM
AudiCross's Avatar
Default RE: smell?
toasty clutch mate. go into 5th gear at a medium rpm (maby 2.5-3k) and see when you mash it if the RPM's raise faster than the speed.
Old 09-07-2006, 01:39 AM
juice88's Avatar
Default RE: smell?
ORIGINAL: AudiCross
yep if that happens u deff need a clutch
Old 09-07-2006, 01:42 AM
johnstef's Avatar
Default RE: smell?
im sorry but i dont know what u just said? go into 5th gear and then what? mash?
Old 09-07-2006, 01:46 AM
juice88's Avatar
Default RE: smell?
put the shifter into 4th or 5th gear and give it pretty much full throttle. if the revs shoot up like crazy, u need a new clutch
kraylon's Avatar
Default RE: smell?
mash=push the gas to the floor
Quick Reply: smell?
