slight vabration under low throttle, Need help finding out the problem
audi a4 1997 awd automatic
-just did coolant flush 500miles ago
-using 15-40 oil, Needle stays at 195degrees
-threw a check engine light
I have this vabration under low throttle, it doesn't happen at high throttle. It threw a check engine light, and I dont have a local shop around me for 60miles that can read the code. The idle feels a little rougher now, but the rpm idle is still dead solid. It is most noticeble in second or 3 gear and giving it light throttle. It feels like the engine. It feels like that same vabration you get on a really old car when you lightly let the clutch go from dead stop to first gear.
Anyone got any ideas? I know it's not motermounts etc... because it threw a check engine light
RE: slight vabration under low throttle, Need help finding out the problem
buy a cheap ebay vag-com cable and read the code. If your car has high milage I would still be suspect of worn motor mounts whether or not you got a code or not.
twinblowersonice
12-13-2007 08:53 PM
