The silver box next to battery.. help!!
Old 03-25-2007 | 04:23 AM
discontained's Avatar
Default The silver box next to battery.. help!!
car is a 01 a4 1.8t.. auto... anyway, I have this problem where the car will die, and wont start back up. It seems like it wont tell the tranny the brake switch is engadged. Normally when i start my car i have to put my foot on the brake to move thru the gears. But when it cuts out i can move thru them without the brake depressed.
Here is where the silver box comes in. Its underneath the driver's side windsheild wiper cowl cover. If i hit that real hard it will let the car crank and run, but it will shut off.. shortly after. I was wondering what this box is? It has "Bosch" , audi rings, and 9 digit code with CH at the end, Please help me.
Old 03-25-2007 | 05:32 AM
Lazer Viking's Avatar
Default RE: The silver box next to battery.. help!!
that would be your ecu.. now stop hitting it
Old 03-25-2007 | 05:34 AM
Belligerenceâ„¢'s Avatar
yeah I'd recommend not smacking it around too much.
Old 03-25-2007 | 05:37 AM
haha does that mean i have a bad ecu?
Like when im driving the car will turn off, flash the OIL light even tho its full of oil than turn it self back on when im in D (this happens withing 2 seconds) and then it wont change gears. It will stay in whatever gear it was in when it turned off which is usually 4 or 5
Old 03-25-2007 | 05:40 AM
oh and i get a CEL code P0600 - Serial Comm Link Malfunction.. whats that?
sounds like something connected to the ecu is loose, if you hit it and it works
Old 03-25-2007 | 06:41 AM
gotaudi's Avatar
When I read through this thread I laughed out loud.... my room mate thinks I am crazy for laughing at a computer screen...
Old 03-25-2007 | 07:20 AM
well **** works when you rage on it.. :P
Old 03-25-2007 | 01:27 PM
CRAZYHAWK's Avatar
The ECU might be loose. Open the box and be gentle with the chip.
Old 03-25-2007 | 01:42 PM
david9999's Avatar
Open up the black protector box and check the connections to the ECU
Quick Reply: The silver box next to battery.. help!!
