sideways quattro
RE: sideways quattro
Thats because Audi's are not made to "a$$ slide"
If you want to drift then get a RWD car. The only time I "drift" is when there is snow on the ground. However, now that I live in Cali that will be hard.
Plus you go through tires to quick.
Josh
Josh
well i think u should rephrase that to sliding or E braking your car around a parking lot since drifting means you have enough engine power to break all four tires loose causing the car to "drift" around the curve under power... you will need a BT set up with at least 300HP and a stasis rear diff that sends more power to the rear, a coilover setup and RS4 rear sway would help too
even the RS4 in the hands of an experienced drifter will have trouble because of the quattro...
so if a 420hp RS4 with a really good drifter cant do it.. i doubt u were...
