Side Airbag
Side Airbag
Hello to All,
New member here and am I glad I found this site! I've done some searches and looked around and can't find the info I'm looking for so thought I'd ask.
I need to access the connection to the side airbag on the driver front seat. How do you remove the panel on the back of the seat?
TIA, Jim
TIA, Jim
RE: Side Airbag
It depends on what model you have, B5 or B6? You would have to remove the seat to gain access to the wiring, or at least tilt the seat backwards. All the wiring comes up through the floor, the connector in yellow is the air bag.
RE: Side Airbag
where can i find cable and software to check codes on a 1998 A4 Quattro 1.8T ?
i think it's a B5, correct?
airbag light is on, not sure which airbag or why. i was told tech bulletin suggest using dielectric grease on connector for side airbags (yellow connector under seats), been there done that, light is still on.
