Short Block optoins
Old 01-02-2008 | 05:35 PM
khj677turbo's Avatar
Default Short Block optoins
Wondering where to look for short blocks, remanufactured would be ideal. Any ideas besides say shokan?
Old 01-02-2008 | 05:41 PM
cincyTT's Avatar
I'm make believe
Default RE: Short Block optoins
Buy the built block being sold here. He has a great setup and is asking $3k shipped for it. Drop it in and your ready for w/e turbo you can dream of.
https://www.audiforums.com/m_736847/mpage_1/key_/tm.htm
Old 01-02-2008 | 10:06 PM
Cincy, i think thats kind of unrealistic for me. I would love a stock bottom end with forged pistons for security measures, say a gt28rs even if i wouldnt need it, i dont need some random explosion and this whole situation of a new motor to arise. Where should i look for say slightly used bottom ends with new rings etc? Or should i just buy a used one and have it overhauled. Id love any opinion.
Old 01-02-2008 | 10:13 PM
cincyTT's Avatar
I'm make believe
just call some shops and see what they can get one for. A used short block should be under $1k
Old 01-02-2008 | 10:19 PM
viper9821's Avatar
OK I have to ask a noob question since i've never read about it. Whats the difference between long and short block? If there is a thread I haven't found link me to it and save a few words.
Old 01-02-2008 | 10:21 PM
cincyTT's Avatar
I'm make believe
shortblock - w/o head
longblock - w/ head
just dont ask me whats the diff between V8 small and big blocks
Old 01-02-2008 | 10:26 PM
viper9821's Avatar
Thanks, I know about those 2 and I wasn't getting them mixed up if you were wondering
Aren't there a few cars in the classifieds being parted with good engines on these forums and audizine also, it's probably worth keeping an eye open. Bore it to 2.0!!
Old 01-03-2008 | 01:05 AM
chaos92287's Avatar
whats up now man? didn't you just rebuild the head? y do u need a bottom end now?
Old 01-03-2008 | 03:06 PM
Chaos, to be honest i dont know what i need anymore, maybe advil. The car only got worse after changing the head. So i ask how could that be? Timing is right on, valves werent bent when taken out etc etc. rings seemed good along with the cylinder walls. I still have a clunking sound which makes no sense because the head should be perfect, and if it was a valve before then surely the head shop would have told me it was a bent valve. I had 180 compression on all cylinders except number 1 which was at 120, now i have 150 on all and 105 on the first. So is the head worse now? clunking sound is still there. THe list goes on and on, and we are trying to diagnose it without doing a motor swap at this point.
Old 01-03-2008 | 04:51 PM
CRAZYHAWK's Avatar
Pour some heavy motor oil in cylinder 1 through
the spark plug hole. Do a compression test. If it
improves the rings are worn.
AudiTurbo
05-18-2014 10:11 AM
antolin
01-06-2012 06:13 PM
zensane
04-10-2011 08:17 PM
auditt225
02-14-2011 12:52 PM
Mixmastermike
02-24-2010 10:26 AM
