service light
service light
So I did my own service at 60k (more like 60, 3xx) but now the service light is on. This doesn't mean anything is wrong right? It's just based on time?
Well now I'm at 64, 4xx and I'm gonna do an oil change soon. Should I change any other fluids while I'm at it? I know oil filter has to go, but what about fuel filter?
RE: service light
nothing wrong it needs to be reset.
button A is the odometer under the speedo and B is the dimmer under the rev counter.
OEL-OIL service light
press and hold button A,
switch ignition on,
release button A,
the letters OEL or OIL will appear in the odometer display of the speedometer.
pull out button B until the letters are erased and replaced by *--*
that's the oil service light reset..
now the inspection service light.
press and hold button A.
switch ignition on.
release button A.
the letters INSP will appear in the odometer display of the.
if required clear the OEL-OIL indicator from the display as previously described
switch ignition on,
release button A,
switch ignition on.
release button A.
