service insp turned off!
searched around and found out how to turn it off...
funny thing is that the dealership will try and charge you 100 dollars plus for this.. HA
the reason im postin this is cause it was different than what was mentioned..
this is for 98 a4
get in the car close the door, pull the button out thats under MPH and turn your key on, dont start the car.
if you let it out it should change to serivice OIL and if you pull it again it will go back to service insp
all you do is pull out on the other button (under the tach) and it will display ---
do that for both and your good.
this is for 98 a4
