Serious issue
Serious issue
I need some good advice from the Audi guru's out there. Ever since I've had my A4 (about 8 months), the speedometer has been giving me issues.. Sometimes it doesn't work, or it will jump up and down. Now I discovered a few things over time.
-When it's cold - below 65 - it almost always works
-When it's hot - 80+ - It almost never works
-When the speedometer isn't working, the odometer doesn't work either
-When the speedometer isn't working, the gas gauge moves around alot (i.e. if i slam on my brakes the gas gauge goes down to E)
-When the speedometer isn't working, when i let off the gas without shifting there is a real strong jerk (kinda feels like the TB closes right away.
-When the speedometer is working the gas gauge is pretty firm and reads right, and it shifts smooth.
I got my speedometer sensor (that goes on top of the transmission) replace with a brand new one and that didn't fixe the problem at all.
So I'm sure it's related to something that doesn't work when it's too hot. What should I do?
RE: Serious issue
If you are saying that the vehicle speed sensor has been replaced, then i dunno what it could be.. If it was just the sensor that was replaced and not the wiring harness, it could be the wiring for it, bad ground or something...
RE: Serious issue
onepoint8tee - yes the vehicle speed sensor was replaced, since thats what i thought it was. it's still doing it so i wasted 100 bucks there...
avant - The CEL did come on once out of 100+ times, and it said it was the VSS. That was on a really hot day where it wasn't working right all day then it finally came on.
djspiel - did you buy a new cluster? how much does that cost?
RE: Serious issue
No, I didnt.
From what I heard the "fading" is a general problem. Most people just turn trip computer off. It bothered me 1st couple of days.. no I am use to it.
I believe for a whole new cluster from dealer it's 600-1000
RE: Serious issue
ORIGINAL: kaklexicon
RE: Serious issue
ORIGINAL: Dj Spiel
No, I didnt.
No, I didnt.
RE: Serious issue
I'm pretty sure it was this one, P0501. But for shitsngiggles can you see what the bently manual says for the other code too? Thanks man.
16885 P0501
Vehicle Speed Sensor Range/Performance
16887 P0503
Vehicle Speed Sensor Intermittent/Erratic/High Inp
16885 P0501
16887 P0503
RE: Serious issue
P0501 = VSS faults could be wiring, speedometer, VSS sensor, CAN data bus.
P0503 = VSS intermittent signal, erratic, high input, faults could be wiring, poor connection, other connected system, instrument panel
