Satellite Radio
Satellite Radio
Just bought an '05 A4 3.0. Stereo has a button for SAT. Anyone know what I need to do to get this activated? The salesman said if Audi activates it I'll pay a ton. Something about a fuse box.
Also, I have a slight vibration at 55-60 mph. Wheel slightly out of balance maybe?
RE: Satellite Radio
You'll need to wire in a Audi OEM sirius (or xm, bleh) reciever. This can go behind your glove box or in the trunk. The antenna also needs to be run. You might need a wiring harness or adapter of some sort.
I don't know what part numbers you'll need, but if you search around the forums you'll find a massive ammount of info on the subject.
Reciever, antenna, wiring harnesses will run you about 220-300.
Milez
Milez
RE: Satellite Radio
Go here, they have alot of part numbers http://www.navplus.us/forum/viewtopic.php?t=894. Also the service dept at audi should have the part number. I would just let audi install it, it you have the loot.
Maxxx
01-07-2010 07:14 PM
