RPM Signal Wire on 01 Audi A4???
Old 04-07-2007 | 07:05 PM
getboosted84's Avatar
Default RPM Signal Wire on 01 Audi A4???
Hi everyone. I just finished searching I have found that there are a ton of write ups on installing a HKS turbo timer on a VW but I have not found one that helps with the install on a 2001 Audi A4. The turbo timer actually comes on and it does it's count down but it doesn't keep the car running. I am in great need of answers to the questions below and if someone could help me out that would be awesome!
1) Where can I tap in to the RPM signal wire for the brown wire on my HKS Type 0 turbo timer?
I have tried tapping into the upper leftmost wire from the service connection right next to the hood lever but that is not working (has voltage but still does not keep the car running after the key is out of the ignition).
2) Where can I tap in to the Emergency Brake wire without running a wire all the way down the center console?
As of right now I have this wire (gray) grounded per HKS's recommendation.
Thanks!
Chris
Old 04-09-2007 | 12:21 AM
Default RE: RPM Signal Wire on 01 Audi A4???
Anyone?
Old 04-09-2007 | 08:38 PM
Old 04-09-2007 | 09:12 PM
new2me's Avatar
Why dont you just tap the tack at the back of the cluster. Or follow the wires down to where they lead.
Old 04-10-2007 | 12:12 AM
ORIGINAL: new2me
That works. Do you know which wire it is so I can tap into it?
Thanks,
Chris
Old 04-10-2007 | 01:00 AM
Lazer Viking's Avatar
i hope to god you arent putting one of those "monster tach's" in
Old 04-10-2007 | 01:10 AM
ORIGINAL: Lazer Viking
lol, I never saw the use for having 2 tachs let alone a big ugly one on my dash. Nope, I am installing a HKS Type-0 Turbo Timer to make sure I allow proper cool down time on the turbo. Which wire was that btw?
Thanks,
Chris
Old 04-10-2007 | 09:38 PM
Is there another forum / board I should post this question on? I really need to know this if someone can help me out.
Old 04-12-2007 | 02:20 AM
No one has an answer for this one?
Old 04-13-2007 | 03:13 AM
ttt, anyone?
