ROYAL PURPLE
ROYAL PURPLE
OKay so I bought Mobil 1 5w-30 synth. but I'm thinking I might return the box and get Royal Purple, Since from reading the threads that its amazing in every way. But my main question is, I also hear that theres royal Purple you can get for transmission fluid. Basically, the main point of getting ROYAL PURPLE oil and tranny fluid is HP increase?
what do you guys think?
RE: ROYAL PURPLE
royal purple is great and i do recommend it, but i doubt that it is that much greater than other synthetics like the one you already bought. you will increase the hp and torque of the car if you were switching from a non synthetic to royal purple but i dont think so if you were going from mobil 1 synth. to RP. i could be wrong tho
RE: ROYAL PURPLE
Those cars that you saw get a 5-10 hp gain were probably domestics. And they went from non syn to royal purple. You would most likely not see any gains at all, and realistically, you wouldn't actually feel the difference of 5 or 10 hp in your car anyways.
RE: ROYAL PURPLE
I use Royal Purple (41). It is expensive tho ($12 a quart).
Last time I got normal royal purple (10w40). It is about the same price as Mobil 1 ($7 a quart)
One thing, Royal 41 do keep the oil cooler than Normal Royal Purple.
RE: ROYAL PURPLE
ya thats the thing, the owner before me got the oil change at Jiffy Lube, cuz theres a sticker on the front window. and im sure those guys used non-syn. Therefore, since i am about to get an oil change, I bought mobil 1 syn 5w 30, but im thinking i should return it and get Royal Purple. which one? and oh yeah what numbers are good for me? i live in cali and it never gets to cold or too hot here.
RE: ROYAL PURPLE
Hey mattn2005 not sure if u have seen this, most us guys round here have though (click on the link in Redgoats post)
https://www.audiforums.com/m_302510/tm.htm
RE: ROYAL PURPLE
i'd say just keep what u got and dont bother with the racing oil unless your that adament about perfection in your audi. u wont see hp increases between synthetics but you might see it from non-synthetic to synthetic. and even then its only slight.
