rough idle
rough idle
my cars been acting up lately, whenever i start the engine the rpms are jumping a little and u can feel a vibration in the car, after about a minute it will go away and idle normally. this also occurs after driving for a little or revving the engine then letting the car sit it will vibrate and the rpms will jump. i have no idea wut this is my CEL light is NOT on. i have replaced, spark plugs, wires, ignition coil pack, can anyone think of anything else??? this is on a 2.8 thank you
RE: rough idle
ORIGINAL: specialK4
RE: rough idle
yea i actually bought that sensor 3 weeks ago when the problem started just never got around to installing it, how hard is it to do yourself?? this problem;s been here for about 3 weeks or so pissing the **** outa me
RE: rough idle
ORIGINAL: specialK4
RE: rough idle
ORIGINAL: a4autocrossr
1.8....i need to replace the sensor also (for a while now)...mind giving me a quick walk thru?
thanks
--E
thanks
--E
Its for a B6, but same location and procedure.
Its easier on a B5 because there arent as many obstructions to get past to get your hands on it. I didnt even need a screw driver to get the clip off. I had no problems at all.
Oh yeah like the article says, make sure the engine is cool and you unscrew the cap on the coolant resevoir tank to relieve pressure and that the ects is seated properlly before you put the clip on. Also make sure you tell the dealer your engine code. Mine is a 4 pin sensor, and i think some other B5 models are different.
RE: rough idle
Also make sure you get the old O ring out, mine was stuck in the flange and didnt get pulled out witht the old ects. it was stuck in there pretty good. and take a paper towel and wipe the inside of the flange out, mine had some gunk in there that can get corroded on the new temp sensor which could be bad.
justinclarke
11-26-2010 02:29 PM
justinclarke
11-25-2010 04:03 PM
