Rough idle
Rough idle
Hey guys. I think my car developed a somewhat rough idle over the last couple days. I thought it was my imagination but I'm not really sure what's up. Throttle response is still good and after I let the car idle for a couple minutes it'll balance out sometimes. But sitting in the car you can feel the engine in there kind of jolting around a little. Plus when I get out and listen to the exhaust it sounds "off". It'll idle, won't die whatsoever, just feels rough. I pulled the filter out of the airbox to see if it was intake related, still same results. I'm thinking fuel filter, but my throttle reponse is still excellent at idel and when at speed, so I'm not really sure where to start. I might get my oil changed in the next week or so, might have them take a look at it. Thanks everyone. ON EDIT: I don't think it's the gas I'm using, running 92 octane and have been using the same place for about a month. Maybe I need to switch?
RE: Rough idle
Well I bought the car 2 months ago and I didn't get a record of when the plugs were changed, I doubt they were. The guy was an Audi technician at a dealer, you'd think he would have done them but at 100K miles some people just don't bother. I was thinking about some of that fuel injection stuff as well, sounds like a plan. Also, I'm not getting a CEL so it's gotta be fuel or plugs or something simple, so that makes me feel a little better.
RE: Rough idle
Was the tensioner changed when the timing belt was done?
RE: Rough idle
UPDATE: Okay so I just drove to and from work and I didn't have any symptoms. WTF?! I think what *might* have happened was when I was driving it early and it hiccuped, I was in Tip and I might have run it a little past where the computer would normally tell the car to shift, you can run the thing to like 6300 or something then it'll shift in Tip so you don't blow the thing up, but you can override the stock shift point in Tip mode to some extent. I wonder if I might have thrown off the ECU and it was pumping too much fuel in there or something? Either way, probably do plugs this weekend cuz they need to be done.
justinclarke
11-26-2010 02:29 PM
justinclarke
11-25-2010 04:03 PM
