ROSS TECH VAG COM
ROSS TECH VAG COM
on the ross tech website, which one do I order? the one that costs $99? or am I confused? is this shareware? what laptop specifications do I need in order to run this? TIA!
RE: ROSS TECH VAG COM
If you buy the cable from Ross-Tech you don't need to buy a software license. There is a software key built into the cable that turns the shareware version into a full licensed version. If you buy an Ebay knock off cable you will need to pay the $100 for a licensed software copy. You buy and old Ross-Tech cable from Ebay, you will won't to make sure that the cable has the software key built in (it called a dongle); because the old cables didn't have them. I think Ross-Tech started putting the dongles in about 1.5 to 2 years ago.
Any old laptop will run the program. I use a laptop that is about 8 years old and it works fine.
thanks dafrazi. so I should buy the cable from ross tech. then is there a place where I get the shareware version for free? or does the cable come with that? a little confused so bear with me. but I want to have this vag. I have the obd II scanner but it only turns the CEL off etc.
is our coolant G12?
is our coolant G12?
You can download the shareware version right off the Ross Tech site, that's what I did. The cable may come with a copy but I don't know for sure. I have cheap Ebay cable that I use for reading and clearing codes. I just borrow dan's Ross-Tech cable when I need to do logging and other stuff.
