resetting the transmission
Old 03-18-2005 | 12:29 PM
rnbguy's Avatar
Default resetting the transmission
how do i reset the transmission? in my audi a4 b5 96 N/A... ive got vag-com...ne tips?
thanx
Old 03-18-2005 | 12:32 PM
Jestnomen's Avatar
6th Gear
Default RE: resetting the transmission
What do you mean by "reset the transmission"? I don't believe it learns like the ECU.
Old 03-18-2005 | 01:02 PM
rnbguy's Avatar
well as in it when it changes gears it seems a little rough, ive vag-com and it says everything is okay (should i do a module search? or thats useless on a 1996???), anyway im thinking the cpu learnt from my previous high way driving and is bringing its "bad habits" into my city driving... anyway to reset that? so it changes gears more smoother?
also one more question.. if i vag-com and it says error codes then i clear them, and test again and they dont come back.. how long should iwait for before knowing they wont come back for good...?
sorry about the 21 questions
Old 03-18-2005 | 01:05 PM
Jestnomen's Avatar
6th Gear
1996 transmissions aren't able to be scanned afaik. The first ones that had a computer were the tiptronic trannies, which started on the 1997 1.8t's. And 1998's on the 30Valve.
You may want to do a transmission flush/fill. It made a big diff when I did mine.
What kind of codes are you clearing?
Old 03-18-2005 | 01:56 PM
Karl's Avatar
Clearing codes doesnt clear the problems.. it just resets it. Its kinda like a Circuit breaker.. if it goes off. you need to fix the problem otherwise you are doing yourself no good. Hope that makes sense I am damn tired
Old 03-18-2005 | 03:14 PM
brrman's Avatar
Jest is correct. The 96's had no adaptive programming. When tiptronic came out the ECU was given the ability to learn/change shift points based on how the user drove it in Tip mode, and lightly translate that over to Auto mode.
Tranny flush will probably do you good.
Old 03-18-2005 | 10:06 PM
rnbguy's Avatar
thanx guys ill try get someone to do me a tranny flush later on this week...
ive reset this error code to do with cylinders.... i dont have the log with me, im at work...
but if the problem still exists it should come back when i retest it right?
Old 03-18-2005 | 10:14 PM
Jestnomen's Avatar
6th Gear
Well you may not see the code in a year or you may see it in a day. It's hard to tell if it was a one time occurance or a repeat offender.
Old 03-18-2005 | 10:34 PM
rnbguy's Avatar
thanx, ill scan it every now n then and if it comes up again ill try get it looked into
so far just over a day and no errors
KpF2007
08-21-2009 07:11 PM
kibs45
07-18-2007 10:03 PM
AudiCross
05-09-2007 10:08 PM
Flippa_s4
09-14-2006 11:50 AM
smythe
06-03-2005 10:12 AM
