Replaced ECT - 2 codes now P1101 P1106 HELP! I have to work!!
What a bummer this has been... I replaced my engine coolant temp sensor and that went fine. I removed the plenum partially to get at it and removed the large vaccuum hose from the throttle body. I also moved around a bunch of wire looms. I lost a bunch of coolant when i removed the thing (opps)...
I put everything back together and checked the hoses i removed. I started it up and 3 minutes in I hear the engine bog down al ittle and my happy check engine light goes on.
I Vagg'd it and got P1101 and P1106.
Could the coolant I lost get onto some wires and cause these codes? Could a vacuum leak? I really have no idea what went wrong and I have work at 8am!
Help!
Help!
RE: Replaced ECT - 2 codes now P1101 P1106 HELP! I have to work!!
Thats a schematic, it doesn't show exactly where the lines are. I see you took off lines from the throttle body as well, did you get the right hoses plugged where they were supposed to be? I would check that as well.
OH ****! I think I know which one it is! there's a ittle tiny line that goes from the plenum to the TB... I bet that's disconnected!
Yep - There's a tiny vac line that goes from the throttle body to the plenum. Rexonnected that and everything is good now.
You win a cookie!
You win a cookie!
dailybeast
06-22-2011 05:48 PM
