Remove the n75, Fuel Cut?
If I remove the N75 and connects the turbo to the wastegate directly, Is there any bad things that can happen then?
Will the Fuel Cut work when the n75 is gone?
am thinking about using a boost controller the get about 0,9bar i boost.. (whit the n75 gone i have 0,5)
sould i leave the n75 plugged in elec.?
The car has a chip for 200hk... and a turbo for 350hk max..
[IMG]local://upfiles/19653/1AD0A084DEEB4745A47C28ED3C50EE26.gif[/IMG]
The car is:
Audi A4 1,8Tq -96
The car is:
Audi A4 1,8Tq -96
RE: Remove the n75, Fuel Cut?
If you choose to use a boost controller, remove the vacuum/boost lines form the N75 valve and route them to the boost controller BUT leave the N75 wire harness plugged in so that you don't get errors and the check engine light.
Also, you won't be able to boost too much over what your chip is set for or else your car will go into limp mode.
skihigh2299
10-11-2015 05:54 PM
DJmart
08-03-2013 11:08 AM
a4, audi, chiped, cut, delete, disconnect, electrical, eliminate, eliminating, fuel, happen, n75, removal, remove, wire
