Rear Sway Bar
RE: Rear Sway Bar
No.
The rear sway sizes are:
Standard -16mm
S-Line and Sport Suspension -18mm
S4 - 20mm
RS4 - 22mm
All are drop-in replacements for each other, meaning if you want to go up or down a size, there is no welding involved.
The bushings fit in the same brackets and you can order all through Audi at a relatively low price.
Standard -16mm
S4 - 20mm
RS4 - 22mm
RE: Rear Sway Bar
I live exclusively in my B7 world and I frequently make this mistake.
My apologies if this info above is absolutely useless to you, JettaRedII.
And to pour salt in the wound, I don't know the answer to your original question.
RE: Rear Sway Bar
Thanks, guys. I should have been clearer. I am referring to the B5. Since the "sport-type" sway bar is under $100, I was hoping for a cheap upgrade. But since I have the sport suspension, I'm going to have to go with something aftermarket.
RE: Rear Sway Bar
ORIGINAL: wood_e
no its 19mm...
no its 19mm...
I really think the B5 Sport Pkg sway bar is 16mm...but whatever, I've been wrong before.
JettaRed, my Neuspeed bar set me back a little over $200 and I've got no complaints. Pretty easy install and a noticable difference.
RE: Rear Sway Bar
ORIGINAL: TheJazz7
B5luver
12-18-2007 12:42 AM
