Rattling Sound, HELP!!
Old 03-10-2007 | 03:03 AM
jstehle's Avatar
Default Rattling Sound, HELP!!
Hello I have a a4, when I drive at lower speeds I hear this rattle coming from the rear. I push up and down on the suspension from the outside and cant hear anything. I only here the noise at lower speeds. On the highway I cant hereit. Any help would be great, Thanks
Old 03-10-2007 | 04:40 PM
onepoint8tee's Avatar
Default RE: Rattling Sound, HELP!!
Could you be a little more specific other than "this rattle"?? Just get under the car and grab stuff and move it around until you find it. Could be an exhuast heat shield. Its also helpful if you mention (or put in your signature) your year/engine when asking questions.
Old 03-10-2007 | 05:20 PM
jstehle's Avatar
The rattle is hard to explain it seems to be coming from the back drivers side, I shake the car outside and cant hear it, only when I drive I can hear it. The car is a 1996 audi a4 2.8
Old 03-10-2007 | 05:25 PM
Well thats where your muffler is, so id get under there and start shaking things, or tap around with a rubber mallet. The baffles inside your muffler may have deteriorated with age and thats what you hear.. Hard to say without being there...
Old 03-11-2007 | 01:58 AM
david9999's Avatar
Is it rattling or grinding? Is it speed sensitive? Have someone get in the rear seat or trunk when you are driving and try to give some better location of source.
Old 03-11-2007 | 06:59 AM
Better yet, get a trunk monkey
Old 03-11-2007 | 04:29 PM
jstehle's Avatar
It is a rattle, not a grind. Ill try and get someone to ride in the back. I cant hear it on the highway, just going at lower speeds and on city streets. It is just very annoying.
Old 08-27-2009 | 12:17 PM
Silver Bullet 4.2's Avatar
Take the wheel off the car and check your spring. Look at the first coil on the bottom. They tend to crack due to corrosion and start rattling. It took mine a year to fracture completely where it was obvious something metal and heavy was broken. The noise only occurs over bumpy roads when the suspension unloads and the coil can rattle. Highway; silent.
Old 10-31-2009 | 05:43 PM
Interceptor's Avatar
Also check the brake pads. If it doesn't sound like it's suspension related and it's happening off and on when it wants to, then I think that would be a good spot to check.
Trevorhealy94
01-13-2013 10:49 AM
sineo
06-11-2011 08:38 AM
09bluea5
09-02-2010 05:30 PM
Zoidberg
06-03-2008 05:41 PM
Audi00
04-25-2007 03:54 PM
