Quick Questions
Quick Questions
Hey guys... Don't mean to be a pest. I also have done a search. I wanted to know if it were a possible way to find out the color grade of your vehicle. Specifically an B5/A4Q Laser Red. I have a new fender on the way, but they need the grade before it's painted. I'm also in the process of doing a regulator replacement... will post pix. The last thing is... I just discovered the location of leak in my coolant resi. I just ordered a new white one, since the one I have is ugly anyway. It looks easy to swap, can I just take the old one out and replace it?
RE: Quick Questions
Reservoir swap is easy. Just drain the fluid from the reservoir and feed line into a bucket, unscrew a couple screws, unplug coolant sensor at the bottom of the reservoir, re-install and re-fill. Easy as pie & chips.
RE: Quick Questions
Thankz so much guys... I've spent the whole entire day looking for that stupid grade. Anyone needing help, I hope u read above because this site sure is hell didn't work.
http://www.automotivetouchup.com/paintcodelocations.htm
