Sponsored by:
Sponsored by:
Quick Question about Lowering/ camber??
Old 10-30-2007, 10:38 PM
QuickQuattro's Avatar
Default Quick Question about Lowering/ camber??
I have a B6 A4 1.8T quattro..... i want to get 18 x 8 front rims and possibly 18 x 9 in the rear...if not 18 x 8 all the way around..
the question is If I get these springs....
http://www.racinglab.com/au20a4qus2w4.html
It will lower the car more than 2 inches front and rear....
how bad will the camber be...i know alot of honda's and such have camber bolts....what do i need....
or should i go with these
http://www.racinglab.com/au02a4qus4wd.html
this one lowers it a little less than 2 inches....
I need you help... i am buying rims and suspension around christmas time....I wanna get my S#!T together!!! thanks!!!
Old 10-31-2007, 08:47 AM
Papachristou's Avatar
Default RE: Quick Question about Lowering/ camber??
yes your negative camber will be way out... your options are
1. find used CPP/STaSIS adjustable control arms since both companies stopped making them, (new were $550-$750) these also made noises and u had to keep them greased up, newer version had a rubber boot to keep grease in
2.Kmac camber bushings (camber plates wont fit a4 chassis) most installers have trouble with them since u have to install them, measure then tweak them... some said they wear out quickly
3.buy tires every 10-15k (the approach ive taken)
Old 10-31-2007, 10:56 AM
ironman's Avatar
thats got to get $$ buying new tires every 15K, i didnt realize lowering like this kills camber so bad, i thought an alignjment and your golden... Hmmmm
Old 10-31-2007, 11:45 AM
B7QUARTZ2.0T6M's Avatar
I would just go with a set of springs from H&R. It will lower the car about 1.5". I'm going to do that in the next couple of weeks/months.
Old 10-31-2007, 02:04 PM
The Russian's Avatar
u dunno man, i lowered my car a good 2.5-3inches, and my camber didn't really chage, i mean yeah it went out a bit, but its still not bad, but then again B5 > B6 lol, no thats a lie both are great, but is the suspension set up really that different ont h two cars?
+1 for "3.buy tires every 10-15k (the approach ive taken) "
Old 10-31-2007, 02:06 PM
turbo kraut's Avatar
Tech Guru
coilovers
and is it just me or are both those links the same thing?
Old 10-31-2007, 03:50 PM
they are not the same links... same company...different drop sizes....on drops like 2.4" and the other 1.7" I was just showing both to see which would be the best to be picked......??
Old 10-31-2007, 03:56 PM
if your lowering the suspension then the wheels have to be determined ( coil overs are great because they can be adjusted ) wheels and suspension? that needs consideration
Old 10-31-2007, 10:34 PM
well i am getting 18 x 8 rims....
Old 11-01-2007, 11:40 AM
ggoodling's Avatar
this is a question i have been considering as well. i have seen some camber stuff on ebay....but it's ebay. good luck and keep us posted on what you find.
Quick Reply: Quick Question about Lowering/ camber??
