Questions Quick!
Questions Quick!
I need some info on a 2001 2.8L A4
1. The Compression Ratio
2. Stroke lenght
3. Tolorances of Rods (Horse power limit)
4. Cam Duration
5. Cam Lift
6. Any known fatigue of Head Studs (Under Extreme Conditions such as Boost)
7. Any Known Weaknesses Of the Engine
2. Stroke lenght
4. Cam Duration
5. Cam Lift
RE: Questions Quick!
10.3:1
2. Stroke lenght
3.40 in. (86.4 mm)
Should be fine around 10psi if you plan on supercharging, I would check out the website (something along the lines of superchargedaudi) if its still around
10.3:1
2. Stroke lenght
3.40 in. (86.4 mm)
cam duration:
intake = 210 degrees
exhaust = 226
valve lift = 8.8mm
im not entirely sure on the HP limit of the 30v.. all i know is that ~10-11 psi out of a G2 is the max it will handle. rods get thown there
as for weaknesses of the motor. the main reason that the 30v 2.8 motor is not recomended for boost applications, is well, it wasn't designed for it..
2.8 motor = Aluminum block and 2 bolt mains
2.7t motor = iron block and4 bolt mains..
the 2.8 motor is just not built for big power. you're much better building up a spare 2.7t block w/2.8 heads and swapping that in..(this is all assuming you're going for 400+Awhp)
exhaust = 226
valve lift = 8.8mm
