Question for people with Test pipes.
I had my test pipe on my car for about 2 months and when I installed it i used the check engine light trick with the 2 spark plug anti-foulers on the rear o2 sensor, i never got a check engine light or had any problem, the car ran perfectly fine.
Recently my car started to back far like crazy... any time a produced more than 5 psi above 3000 rpms there would be constant back fires.
I have a friend with a Vag who ran it on my car and it told me that the rear o2 sensor was not giving out any signal, I have never changed my o2 sensors and i have about 73,000 miles. The vag also read that i had misfires in 2 of my cylinders but that there were 2 different types of misfires and mine was the not so bad one.lol.
Heres what Ive done:
Replaced n75 valve , replaced MAF, ordered 02 sensor and awaiting the arrival.
What Im wondering if that by having a faulty 02 sensor would it cause your car to back fire like mine has?
If I replace the 02 sensor and the backfires still continue does anyone have any other suggestions? I like my testpipe and would perfer to keep it if possible.
RE: Question for people with Test pipes.
Clear the codes, replace the spark plugs drive for a day and retest. If you have a misfire gas could be igniting in you exhaust. I wouldn't worry about o2 sensor, is it disable for the test pipe with the chip? If you o2 sensor is bad and not disabled it would turn on the cel.
well.... i have a giac chip so no the chip isnt programed to turn the test pipe off.. I never had a CEL until this started to happen and now i do have a cel. I did change my spark plugs, it was the first thing i did and nothing changed
does it backfire as your accecelerating or when your off the gas? do you have an after market exhaust? is it resonated? I have a testpipe and it backfires only on decelaration but its normal becuse I have a non resonated turbo back exhaust
mrbillmartin
04-01-2014 09:43 AM
jakgtrey
05-20-2008 11:02 PM
